creeking/ binding sound??? HELP!
Old Oct 9, 2002 | 09:28 PM
Red02LS1's Avatar
Default creeking/ binding sound??? HELP!
i had Global West subframes, BMR poly/poly LCA's, eibach springs, and panhard bar put on the car. Now when I let the clutch out and leap the car forward, there's a loud creeking/binding sound comming from under the car. The dealer replaced the driveshaft and U-joint, as it sounded like it was comming from the rear end. It happens when you move between reverse and 1st the most, and sounds like the suspension. What could it be? Mabye the Poly LCA's??
