noises after panhard bar and LCA install?
Old 08-04-2006, 04:26 PM
shudog's Avatar
Originally Posted by UMI Performance
Thank You!
And yes we get very minimal to no complaints regarding this issue. For manufacturing and selling hundreds of sets this is really the first time I have seen this. The first issue is rod ends, the majority of you are running either rod end/rod end or poly/rod end. Although we use high quality rod ends lets face it, you are replacing a 2" think rubber bushing with a solid joint that has no deflection. If you want that correct performance from your vehicle then some sacrafices must me made, rod ends being one of them. If you do not want any noise issues then you may need to stick with a item that will work but just not be best fit for your application.
Regards,
Ryan
Ryan, I have a set of the UMI poly/rod end LCA's and the PHB waiting to be installed. Do you recommend I install new bolts rather than reuse the factory bolts? If I should replace them, what size? The stockers seem to have a bit of play inside the LCA bolt hole... could contribute to some noise, right?
Quick Reply: noises after panhard bar and LCA install?
