BTS suspension
Copy and paste this link in a new browser window. This was take right after the install.
http://www.geocities.com/maketherightcall/P1010098
I wanted something matched and designed by Bilstein and I'm very happy with my choice.
My one and only complaint though, Bilsteins warranty dept is deplorable.
Hope this helps...
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 01Z28vert:
<strong>Is anyone here using the bilstein bts suspension system on their car. It comes with shocks and bilstein spring. Its kinda hard to find, i was at jba the other day and saw a brochure for the kit but never heard of anyone using it. If so how much does it drop the car and is it a good setup? thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
<small>[ November 06, 2002, 02:16 PM: Message edited by: MODMYZ ]</small>
<strong>I have it installed on my Z (I'm probably the only one here who has done it), the car dropped perfectly all around and the handling/stance is greatly improved. Expect the ride to be a little rough though. The spring rates are matched to the shocks which are Bilstein HD's, that way the springs (made by Hyperco) won't wear out the shocks.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually, the spring rates are not well matched to the shocks. If they were, I'd sell the BTS kit instead of going through the trouble of revalving the shock all the time. The BTS is not an outright performance package, you can determine that by the use of the progressive rate springs. And yes, the ride is a bunch harder than it has to be because the spring rates are stiffer than they need to be IMHO.
This is why I tend to stick with Eibach Pro-kits (more sane rate, and linear too). Linear spring are much easier to damp properly, which is why race cars don't use progressive spring BTW. Further info: Bilstein HD's are actually lacking in high-piston speed rebound when compared to even a stock DeCarbon. This combined with a much stiffer spring rate isn't optimal.
<small>[ November 13, 2002, 07:30 AM: Message edited by: LuS1fer ]</small>
