Rear bottoming out
Old Nov 16, 2002 | 05:43 PM
BadAssY2KTA's Avatar
Default Rear bottoming out
I have an eibach prokit and KYB 8 way adjustable shocks, and all other suspension bolt ons, and a moser 12 bolt. And my problem is even with my shocks on the stiffest setting my rear suspension will bottom out and hit the stops. I have removed the spacers from the stops, and if i make the stops any smaller the tires will hit my fender wells. What else can i do to solve this problem?
Old Nov 17, 2002 | 09:27 AM
mitchntx's Avatar
Default Re: Rear bottoming out
I had to remove my Eibachs and go to the G2 Super Spring from LG Motorsports.
Problem solved ...
Old Nov 21, 2002 | 04:54 PM
acarnut's Avatar
Install a set of air bags in the rear coils (Airlift 1000 kit p/n 60797). Plumb them independently (so they don't exchange air pressure in the corners) and run 5 to 8 PSI in each. Also works great if you plan to have passengers in the back or a heavy load.... in my case that would be a lawn mower, a foosball table, and many trips to the lumber yard.
It may raise the car a tiny bit, but it will add a progressive + *adjustable* compression rate to your rear springs.
DaveH
http://member.newsguy.com/~acarnut/
Old Nov 23, 2002 | 07:35 PM
Racehead's Avatar
You can remove the rear springs and add a section of heavy duty hydraulic hose to each end. This will raise the *** end a little bit and give you more suspension travel.
