Torque arm
Old Nov 16, 2002 | 06:03 PM
blu3bird's Avatar
Default Torque arm
I am about to get a torque arm. I was wondering about the Spohn TA. Does anybody have it and how do you like it.
Old Nov 16, 2002 | 07:49 PM
2FAST4U's Avatar
Default Re: Torque arm
Sorry I don't like the spohn part they don't look very good. Meaning the bars are small and the quality is not the best. For the money go BMR cheap and a very good torqe arm.
Old Nov 16, 2002 | 08:02 PM
blu3bird's Avatar
I would like to get one that bolts in,I think.
Old Nov 17, 2002 | 02:10 AM
Magic Man's Avatar
I have the Spohn unit and have no complaints and it does get it off the tranny and you can also get it with D/L.
Old Nov 17, 2002 | 09:25 AM
mitchntx's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by blu3bird:
<strong>I would like to get one that bolts in,I think.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Then you need to look at LG Motorsports Torque Arm ...
A direct bolt in, requires no drilling, welding or hacking of your car. Uses the stock mounting points. will NOT interfere with ANY exhaust configuration. And best of all it works flawlessly.
Old Nov 17, 2002 | 10:19 AM
2FAST4U's Avatar
BMR makes 3 different ones. One bolts in, Tack pak, and xtreme duty.
Old Nov 17, 2002 | 10:38 AM
blu3bird's Avatar
Will the Spohn hold up to a heads and cam car with et streets? I am going to look at the L.G.motorsports also.Thanks for the help everybody <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 18, 2002 | 01:24 AM
02SilverWS6's Avatar
I know Edelbrock has a torque arm for cheap. I think it's under 2 c-notes...check it out!! Do a search on this forum for the thread. They rave about it!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Nov 18, 2002 | 09:09 PM
theblur98ss's Avatar
I had a spohn and was very happy with it. It was a very heavy duty piece and had the loop built right in. I only got rid of it because the x pipe wouldn't clear it.
Old Nov 26, 2002 | 02:39 AM
Yellowhammer's Avatar
I have the Spohn ta. I love it. I got the spircal end. Haven't gotten it adjusted just right yet, but after installing it there was a awesome improvement of rear power.
It was a breeze to install and much better than the stock piece, would recommend getting one.
Only complaint is that it can be noisy, but I think I haven't set it up properly yet.
Old Nov 28, 2002 | 11:18 AM
trackbird's Avatar
We just installed a Spohn torque arm on a 92 Z-28 with about a 350hp motor and it was very well made and works great. The only concern was that it is very close to the trans tunnel at the rear end and may be rubbing the body slightly (have to get back under the car and check). The LG arm and the Edlebrock arm look to be excellent parts as well....Good luck.
Old Nov 28, 2002 | 04:47 PM
DBerry's Avatar
I've got the BMR Extreme Duty on mine. I don't like it. I had to have the holes in the bracket that bolts to the rear welded up and redrilled, in order to keep it from hitting the DS tunnel. I called BMR about this and they wouldn't do anything about it. The front mount welds to your SFC's and if you don't have the BMR SFC's that can be a problem. Also have a thumping noise right under the front seats everytime I change gears or get on it enough to make the rear wheels hop. I don't know if that is typical whith the Spohn or not?
I've been looking at taking mine out and going to the Spohn or back to a bolt in design. What sucks about that is now I'll have to buy a new set of SFC's also because I had to cut one of the braces out of my SLP's to put the mounting bar for the T/A in <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Nov 28, 2002 | 06:21 PM
mitchntx's Avatar
Another reason why LGMs TA is a superior unit ... no fabrication necessary ...
Old Nov 28, 2002 | 07:00 PM
MRC95Z's Avatar
just to let you guy's know I have personally fixed 3 Spohn TA. The front of the TA broke. I have seen alot of problems with those. Also you are better with something that has a dedicated mount for the front of the TA, Cars with alot of power put alot of stress when attached to tranny
Old Nov 28, 2002 | 07:09 PM
ROBS SS's Avatar
<strong>Will the Spohn hold up to a heads and cam car with et streets? I am going to look at the L.G.motorsports also.Thanks for the help everybody <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have the spohn on my car with 0-problems, im getting 1.32 60's and im making twice the HP and TQ most of you are making, I really doubt you can hurt it <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ November 28, 2002, 07:14 PM: Message edited by: ROBS SS ]</small>
Old Dec 3, 2002 | 04:21 PM
Ian's Avatar
Ian
Anyone have any opinions on the Global West TA's?
Old Dec 3, 2002 | 05:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Global West Trac-link is more handling oriented since it's a shorter tq-arm but it's a decent performer on the racetrack.
I run the Random Tech tq-arm and have cut 1.4 60 ft times BUT I have every suspension part available and run 28" slicks.
If you are M6 you might want to get the front mount of the tq arm off the tranny, but I think A4's can run a stock style torque arm into the 10's no problem.
