Differences between K-Members?
Old Nov 20, 2002 | 11:05 PM
ONE BAD BIRD's Avatar
Default Differences between K-Members?
Hey I need to buy a new k-member for my 02 ws6 convertible, and the part number is different between the convertible and the one I found for a coupe. Whats the difference? Would the coupe one work?
Jaxon
Old Nov 21, 2002 | 11:27 AM
12secSS's Avatar
Default Re: Differences between K-Members?
It would help if you told us what vendor you are talking about? There should be no difference between the convt. and the coupe's K-Member, subframe connectors is a different story.
Old Nov 21, 2002 | 01:44 PM
I need to swap it because its bent, I bought the car as a total loss.
Have you got any pics of your tubular one? I'd rather replace it with an aftermarket peice than a stock one.
Old Nov 22, 2002 | 12:20 AM
Joe99SS's Avatar
there is a little difference... I just changed the oil on my sister's '02 TA 'vert and noticed the 2? little support bars that mount on the front of the k-member and extend outward to the a-arms for stiffness I presume? That was the only "noticeable" difference I saw... If I were replacing a k-member I would just swap to a tubular one. I have the BMR unit on my SS...
Old Nov 28, 2002 | 08:11 AM
highgmc's Avatar
you can use a regular k member, no need for a special convert. one.
sell ya my stock k member for $100 if you pick it up.
