Which set up will get the most traction and best time?
A 275/40/17 Nitto NT-555R Drag Radial on a stock 10 spoke SS wheels or a 15" or 16" drag wheel with a Nitto drag radial on it. Will there be any differece in traction or a difference in 60' or 1/4 mile time? Will a 15" rim fit properly with the stock caliper and no modifications? If not, will a 16" fit? What would be the best size if I was to go with a 15" or 16" that I wouldnt have to make any other mods?
Re: Which set up will get the most traction and best time?
As far as wheels go, buy yourslef some sock Z28 16" rims. ALUMINUM, not chrome. They are sure to fit, they are light, and you can fit a taller sidewall on your tire, that can allow for a little more flex.
Plus you can find them CHEAP!!!
