HELP, Please...... Front part????
Old Jul 24, 2006 | 05:02 PM
30thz's Avatar
Default HELP, Please...... Front part????
The part circled in red. What is the correct name or part number for this part? I call it a spring perch but the dumb as at the dealer shows only one listing and its $200.
On GM parts direct I found a SEAT Part # 22099275 price $22.00.
Any help would be greatly appreciated. Thanks in advance.
Old Jul 24, 2006 | 06:08 PM
1999Z28's Avatar
i'd call it the upper shock mount
can't be more than 20 bucks
Old Jul 24, 2006 | 06:14 PM
Turo's Avatar
I thought it was called the spring perch also . I hope that little thing doesn't cost $200!
Check out the pic I have attached, it looks like part 53, but I'm not sure. If it is, my little manual says that is "MOUNT, FRT S/ABS UPR", part mumbers: 22146933 (left) and 22146934 (right).
May want to wait for someone else to double check that though, I'm not sure how accurate my little parts manual thing is.
Old Jul 24, 2006 | 06:21 PM
Viper's Avatar
It does cost $158.00, check gmpartsdirect.com
Old Jul 24, 2006 | 06:22 PM
30thz's Avatar
Turo thats it, I just found that same brake down on a google search.
That damn thing is $239 from the local dealer, $95 from GM direct.
Old Jul 24, 2006 | 06:55 PM
mitchntx's Avatar
Monroe replacements from O'Reilly's are under $100 ... and they SUCK!
I twisted the threads out of one ... POS ...
Old Jul 25, 2006 | 10:57 AM
Sam Strano's Avatar
LS1TECH Sponsor
I've sold and installed a few of the Monroe mounts, and had no trouble at all. Worked great, and came with new nuts and bolts too. Those studs are pressed in and aren't supposed to be torqued to a huge degree. Could have just had a bad one you know.
$95 is what I sell them for. FWIW.
__________________
Old Jul 25, 2006 | 11:57 AM
trackbird's Avatar
We got an off brand from Advance for Pimpmaro's car and it had aluminum threaded inserts. They didn't line up with the holes, cross threaded and "spun". We then got one from NAPA, it was steel and looked identical to the original. I'm sure it came from the same assembly line, or is an exact copy (down to the welds) of the OEM version. The price was far more reasonable than GM's. Call your local store for pricing, it varies by area.
Old Jul 25, 2006 | 12:11 PM
mitchntx's Avatar
Exactly what I found.
Sam ... what brand are yours?
Old Jul 25, 2006 | 12:45 PM
Viper's Avatar
mitchntx
He sells the Monroe brand.
Old Jul 26, 2006 | 10:09 PM
justinbmx's Avatar
I got mine at napa for 72 dollars. It is called a strut bearing plate
Old Jul 26, 2006 | 10:25 PM
mitchntx's Avatar
Originally Posted by Viper
mitchntx
Doh!!
Old Jul 27, 2006 | 10:00 AM
Sam Strano's Avatar
LS1TECH Sponsor
I can order KYB's also, but they aren't normally in stock.
__________________
