Kenny Brown subframe connectors
I've got mine sittin on the floor here, but won't have them installed untill after christmas.
Anyone have pics of them installed on a Camaro from the side? I called KB and asked them a few ???'s about the SFC's... one of which was will they be seen from the profile. he said nope.
I just can't believe that. Can anyone show me any GOOD pics of their Camaro from the side with KB SFC's?
Thanks,
Shane
Thanks,
Shane
I'll try to remember to go home and take a picture today though I have plans tonight so I might have to take the picture tomorrow. However, I can tell you that indeed you cannot see them from the side. Or, if you can, you'll see about 1/4" of it. The KBDD SFC weld onto the inside of the lip that you use the stock jack to jack the car up. Does that make any sense? Basically, there is a lip on both sides of the card that runs from the front wheel to the back wheel. At places, this lip is welded together so you can use it as a jacking point. The KBDD SFCs weld to the inside of this.
Sweet!
I appreciate it! I'm jonzin big time to have these rigs installed! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
You would have to lay on the ground to see KBDD's if they are installed properly. Check out this pic from my website >>
http://www.californiamasseys.com/DVC00064.JPG
The goldish looking piece under the door is the KBDD's. The piece hanging down further right behind the front tire is a custom Y-pipe that sits less than 3 inches off the ground. Ouch!
I have lots of pics of my car at the website, and you'll note that the only one that shows the SFC's are the ones where I layed down to see them.
http://www.californiamasseys.com/formula.html
Mike M
Mike M
