98+ Camaro front end aerodynamics?
I was wondering if there's anything in the 98+ Camaro front ends that starts to act as an "air brake" at high speeds? anything as in fog light housings? or the front grill moving air about the wrong way? Would it be better to run with or without a factory grill? things like that...
Basically is there anything "factory" that's hurting the car's aerodynamics?
Check this link out https://ls1tech.com/ubb/cgi-bin/ulti...c;f=3;t=003645
email me if you want some info. I am currently building a front end using carbon fiber,fiberglass and sheetmetal to make a completely smooth front end with an integrated air dam. Beleive it or not I went out and bought a Revell model and some bondo to make the thing to scale. Once you get an idea of what you want. you start building.
