Lowering car
Old Jan 1, 2003 | 08:02 PM
2000Z28NBM's Avatar
Default Lowering car
Hello guys,
A while back I brought American Racing Torque Thruster II's (9.5 inch I believe) for my Z28 A4. I also upgraded my tires to 275/40/17 all the way around. I'm thinking about lowering the car, what would be the best kind of shocks and springs to buy. Also what else would be needed for the drop. I do not want anything more than 2 inches. A 1.5 inch drop would be my preference.
The car is a daily driver also.
Thanks...
Old Jan 1, 2003 | 08:33 PM
6']['9's Avatar
Default Re: Lowering car
id go with either a pro kit and some bilsteins for a daily driver i just ordered mine and they should be on in about 3 weeks. you might want to get a PHR to recenter the rear since your lowering it... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
good luck
Old Jan 1, 2003 | 08:48 PM
2000Z28NBM's Avatar
Excuse me for my ignorance but what is a "PHR". Anyhow thanks for the info, i'll check into the shocks & springs.
Old Jan 1, 2003 | 09:06 PM
6']['9's Avatar
pan hard rod thats ok <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jan 1, 2003 | 09:07 PM
unit213's Avatar
Administrator
A PHR is internet slang for a panhard rod. You actually need an APHR, which is an adjustable panhard rod if you plan on re-aligning the geometry after the drop.
Old Jan 2, 2003 | 03:19 PM
Ackattack's Avatar
don't forget lower control arm relocation brackets.
Old Jan 2, 2003 | 04:05 PM
Fulton 1's Avatar
For a nice daily driver-type ride with about 1.5" drop I would recommend:
- Eibach prokit springs
- Sam Strano Revalved Bilsteins or SLP Bilsteins
- Adjustable panhard rod (if needed - measure after lowering)
- LCA relocation brackets (BMR bolt-in work well and are easy to install)
- Alignment
Old Jan 3, 2003 | 12:42 AM
RutanZ28's Avatar
Honestly, I haven't ever seen any complaints on any brand of lowering springs. Some lower the car more then others, just depends on your taste. A few I have seen used are Eibach sportlines, Eibach Pro kit, LG Motorsorts G2 Super springs (I think these are still on back order), Hypercoil (LG has these on sale I believe for like 25% off or something, and I am sure there are others. You will also want to buy an adjustable panhard rod to re center the rear. LGmotorsports also has theirs on sale right now for 25% off and you can even get it on layaway. Anyhow that's about all you need to lower the car. I would also recommend though maybe an aftermarket shock like maybe a bilstein or something to go along with it to get that little extra handling boost.
just my $.02
Old Jan 3, 2003 | 04:35 PM
2000Z28NBM's Avatar
You guys have been great. Thanks for the info. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
