Still no traction
Koni SA's (Full Soft)
Hotchkis sways
BMR LCA's
BMR TA
Tires at 24psi
Any other ideas???
Hotchkis sways
BMR LCA's
BMR TA
Tires at 24psi
Any other ideas???
Are you doing a burnout? Heating a street tire will make them very unsticky.
The real solution is a better tire. Even someone else's worn out Nittos on a spare set of factory wheels would make a world of difference.
Back when I had a completely stock suspension, just bolting on a set of 27" ET Streets allowed me to dump the clutch at 6600 rpm and dead hook! I was cutting 1.75 short times with boltons in my full weight daily driver.
Ben T.
To get good times on street tires, you'll need to ride your clutch out at the line, but right now you have a clutch that can't really be slipped. It needs to be revved up and dumped.
It's a difficult situation to be in. If you rev it up to 2000 RPM and dump it with a drag radial, you'll probably bog (but get good traction). This might be your best bet. If you rev it up to 4500 and dump it on a drag radial/slick, then your car will run like it should, but you risk breaking.
I see sort of three options,
1)Drag radials and "moderate" launches using "moderate" shifts
2)Slicks and a strong rear
3)A factory clutch (LS6) slipping the clutch at the line (using street tires)
Keep in mind I'm only one person, and this advice is free. I'm not a career racer, nor do I own a shop that builds race cars.
Ben T.
Certainly worth trying if you don't have a set. You want the front of your LCAs to point "uphill". This will move the IC back further on your car and will transfer more weight over the rear axle helping traction.
Ben T.
I don't have any idea what springs he's on. And that could be a problem if they are some of the crazy stiff rears that some companies make. It's not his front bar. You have to get some sort of traction to lift the nose in to start with for the front bar to be hurting. Sounds like he's not. And it's not the shocks. The rear Koni's are not stiff on compression, and when turned full soft in front are quite soft--and again, if you don't have enough mechanical grip to start with, the shocks won't matter anyway.
I'd say change tires. LCA brackets might help, and are cheap starting @ $59 for a set. I don't use them a lot because we are more into handling than drag racing around here, but we do carry them because I know that other people have other goals.
UMI LCAs, STB, PHR
MAC Sfc
Stock 10 bolt, stock torque arm, stock engine and tranny mounts at the time
stock springs, F&R swaybars
Last but not least my awesome Monroe sensa tracs
Thats where having fully adjustable spherical suspension would come in
Not sure what your hp/torque is but I have koni adjustables all the way around and Strano swaybars and have no problem whatsover with traction on the D3's.
Also, pretty much an street radial is goingto spin by dropping the clutch at 2000 rpms. You have to slip it a bit.
1. Raise the tire pressure back up.
2. Slip the clutch a bit from around 2500 to 3000 rpm.
3. Or go to DR's but you're rear may blow up.
