How hard to remove front sway bar?
It is easier than changing your oil. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Get under there and remove 6 or so bolts.
Its actually so easy the I removed the stock one and replaced it with my BMR swaybar with out jacking the car up. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Alan
Alan
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
if you just want to unhook it for the track you can fully remove it or some people just remove the rod ends and secure the bar to the frame so it doesn't hang down.
I don't know about you all but when I removed mine the end-links(ends that attach the the lower control arms via the long bolts) broke off, on both sides. I was using just a wrench on the bolt and a 1/2 inch drive ratchet/socket on the nut. I sprayed a little WD40 but they were so rusted they just broke off. So now if I want to put it back on I have to buy new end-links! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
