3 point sfc vs 2 point
are 3 point sfc that much stronger than 2 point? 2 point are around 150 while 3 point are 260. Im also ordering alot of other itmes and the extra cash could be put somewhere else. The only 2 points iv found are weld in only, id like Spohn since you lose no ground clearence with them, my car is lowered on a pro-kit. If i get 3 point it will be UMI. Car is a DD but i got to the track around once a month. T-Top M6. Thanks alot
Hello,
You will be just fine with the 2-Point set-up, they do there job nicely with no issues. If you are looking for a bolt-on set-up we do have them and I will be glad to help, we also have weld in's. Our 2-Point bolt-on set-up is a 100% bolt-in and requires no drilling, cutting or grinding and can be installed in 20 minutes. They also tuck up very nice and can not be seen from the side of the vehicle, you have to bend over and look to see them. I pasted a link below to this set-up, if you have any questions please ask and I will be glad to help.
www.umiperformance.com/2002.aspx
Thank you
Ryan
Thank you
Ryan
