Need Help installing ARP wheel studs
Old Jan 30, 2003 | 10:48 PM
Down's Avatar
Default Need Help installing ARP wheel studs
Does anyone know how to do this? Any tips or pointers? <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
Old Jan 31, 2003 | 02:52 AM
Top Fuel's Avatar
Default Re: Need Help installing ARP wheel studs
for the rear, I read somewhere on here before that you don't have to pull the axles, but its easy enough to pull them so I did.
install of studs:
- pound the old one out
- slip new one in
- throw a stack of washers on stud
- put your lug nut on the stud
- impact her down
later,
Steve
Old Jan 31, 2003 | 10:08 AM
Down's Avatar
thanks for the info but im doing the front i think that might help though
Old Feb 2, 2003 | 10:15 PM
Down's Avatar
yes you are right but i called thunder racing to find out & they said they would fit with no problems. i just might take it to my friend who works @ the dealership to install them.
Old Feb 2, 2003 | 10:20 PM
Down's Avatar
Old Feb 2, 2003 | 11:50 PM
pony killer's Avatar
just pull the rotors and they shoud be easier than the rear <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Feb 3, 2003 | 12:55 AM
2001CamaroGuy's Avatar
I noticed the ARP studs have a measurment of 12mm X 1.5, 2.5" length.
Correct me if I'm wrong but that means:
12mm bolt
1.5" of thread
2.5" overall length
is that all correct? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Are there any longer studs that are direct replacement?
Old Feb 3, 2003 | 11:09 PM
trackbird's Avatar
It is really recommended that you press studs in (less chance of damage to the mounting holes or other hardware). I know that nobody actually does this anymore, but it really is a good idea. Other quick note, make sure the knurled portion of the stud does not stick out past the mounting surfaces (axle flange, etc), you can have strange brake problems when the rotors are press fit to the knurls on the wheel studs.....Just my $.02
Good luck
