Line Lock help?
Old Feb 2, 2003 | 05:35 PM
SLowETz's Avatar
Default Line Lock help?
Installed the Hurst unit, bled the system(5 times)until there was no evidence of air in the lines. Solenoid engages,(and does engage the brakes) but doesn't hold the car still during the burnout
Keep bleeding off the lines....or is there something else I could look at? TIA!.......
Old Feb 2, 2003 | 07:33 PM
ss rally red's Avatar
Default Re: Line Lock help?
Are you mashing the pedal like you mean to stop hard? The first time used my slp line lock I didn't apply brake pedal hard enough and it rolled. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Feb 3, 2003 | 01:17 PM
JRcamaroZ28's Avatar
I have to pump mine 2-3 times and then it holds solid also.
JR
Old Feb 4, 2003 | 12:21 AM
LOnSLO's Avatar
Pump your brakes hard a couple of times before you hit the switch. Make sure your brake is fully depressed also.
