KVR Rotors
I am looking into KVR rotors from Fast Toys, I would like baer eradispeeds but I cant afford them. I think this may be the next best thing for the price. I have warped rotors after some hard stops from some high speds and mid speeds. I also have a question about candium coating does this wear off from the brake pads rubbing up against. Please share your experience.
Thanks in advance
Thanks in advance
Cad plating will wear off where the pads touch the rotor, but the rest of the rotor should remain shiny and rust free. If the surface rusts from rain, the first time you use the brakes, it will clean off the rust and you'll have shiny rotors all over again.
Haven't tried KVR's, but there are some other posts on here about them. Good luck.
