Suspension newbie...input on possible setup?
Plans as follows: DMS springs, adjustable panhard, 2pt STB, lca's and relocation brackets. For shocks I was thinking some bilsteins (possibly revalved?) in the rear and then some koni SA's in the front so I can set them full soft for the strip to launch better.
How well will all of this work together? Again I'm trying to find a good compromise between a mostly daily driven car and a car that can also handle some drag strip time as well as a little autox.
Thanks in advance and sorry for the long post!
<strong> I'd recommend you use a set of LCA's with rod ends (heim joints) on both ends (eliminates binding for autocross and handling...but makes some noise). THe panhard rod really dosen't have to rotate, so you can get away with poly bushings there (but make sure it is adjustable...I still use rod ends, less slop and poly can "cold form"....after repeated loads, it will "dent" and get sloppy....but it takes a while. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree on the heim joints for the LCAs and the panhard rod. Personally I think heim joints are the only way to go. The panhard rod (aluminum w/ heim joints) was the first mod (suspention wise) I made and I was amazed at how precise and predicatable it made the handling. I didn't really receave any increase in road noise from the panhard rod. Where I got the noise was from the LCAs and part of that is because I didn't really clamp the bolts down so they were able to wiggle around on bumps. Get the heim joints.
Chris
