So basically all panhards are the same?
Old Feb 14, 2003 | 06:36 PM
Z-Rated's Avatar
Default So basically all panhards are the same?
I mean really, does it matter from brand to brand? i am thinking about the Billingsly one. b/c its spherical and its double adjustible so i dont have to take it off the car to adjust it... makes life easier. then i looked into it and so does the BMR unit. it has spherical ends along w/ the ability to adjust it on the car. so will there be a noticible increase of road noise w/ spherical ends? i know w/ LCAs you can tell but what about the panhard?
Drew
Old Feb 14, 2003 | 08:08 PM
DONAIMIAN's Avatar
Default Re: So basically all panhards are the same?
Now that I think about it, all panhards really are the same. Except for the ends thought, some like to use cheap ends some like to use good ends. You just gotta do research on em to make sure you dont get screwed. The rod ends on a APHR will make it a lil louder, but not like you think. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 14, 2003 | 09:13 PM
2001CamaroGuy's Avatar
They are all the same in design. As has been said though, some MAY use better rod ends than others so check that out. Any of the big companies (BMR, LG, etc....) use good parts.
Chris
Old Feb 15, 2003 | 12:58 AM
Z-Rated's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2001CamaroGuy:
<strong> They are all the same in design. As has been said though, some MAY use better rod ends than others so check that out. Any of the big companies (BMR, LG, etc....) use good parts.
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">See thats what i was thinking. Has anyone noticed a change in road noise w/ rod ends? either way i think ill get the spherical ends. thanks guys
Drew
Old Feb 16, 2003 | 09:04 PM
If you keep the mounting bolts tight, you won't really receave any more noise. Its when they are loose and can rattle over bumps.
Old Feb 17, 2003 | 08:25 AM
Top Fuel's Avatar
If you are weight conscious, that is something that makes them different as well. The G2 and Billingsley panhards should be the lightest out there.
Steve
Old Feb 17, 2003 | 11:12 AM
mitchntx's Avatar
<strong> If you keep the mounting bolts tight, you won't really receave any more noise. Its when they are loose and can rattle over bumps. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not entirely true ...
I had a BMR APHB with rod ends. As the diff moved up and down, the rod itself would twist back and forth, hitting the body mount with the rod end housing.
Old Feb 18, 2003 | 10:19 PM
trackbird's Avatar
My BMR panhard rod with rod ends seems to be hitting my upper panhard rod, it has since it was first installed (and the car was almost brand new (under 1500 miles). It dosen't make much noise, but it will clang and bang on hard bumps....but it's worth it. Good luck.
Old Feb 23, 2003 | 04:23 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Top Fuel:
<strong> If you are weight conscious, that is something that makes them different as well. The G2 and Billingsley panhards should be the lightest out there.
Steve </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That is if they are aluminum.....I have the Z Rated Motorsports aluminum one and it is REALLY light.
Old Feb 23, 2003 | 04:26 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mitchntx:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2001CamaroGuy:
I had a BMR APHB with rod ends. As the diff moved up and down, the rod itself would twist back and forth, hitting the body mount with the rod end housing. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I get what your saying...thats like what my LCAs did (also have double rod ends on them). What I did to get rid of that was turn the rod ends out off alighnment (so they are not stright up and down). This prevents them from being able to rotate very much and got rid of all the clicking.
Chris
Old Feb 26, 2003 | 05:04 PM
2MCHPWR's Avatar
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">FYI...BMR does NOT use the same joints as LG. BMR's are cheap and noisy; LG's uses high quality helm joints. no comparision
Old Feb 26, 2003 | 09:24 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2MCHPWR:
FYI...BMR does NOT use the same joints as LG. BMR's are cheap and noisy; LG's uses high quality helm joints. no comparision [/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">But my LCAs don't make any noise and they have been on the car for some 10,000 miles. I'm not saying the BMRs are better (or even as good as) than the LGs, I'm just saying they don't seem too bad. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Chris
Old Feb 26, 2003 | 09:55 PM
Z-Rated's Avatar
Thanks guys. i found a used panhard the other day so i am in the process of getting it. thanks ohh its a BMR
Drew
Old Feb 27, 2003 | 10:17 AM
Dom's Avatar
Dom
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mitchntx:
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Wouldn't that also cause bind in one direction. You basically prevent the rod from moving in the direction you turn it. Kinda defeats the purpose of a rod end, might as well get poly.
Old Feb 27, 2003 | 01:38 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dom:
<strong> Wouldn't that also cause bind in one direction. You basically prevent the rod from moving in the direction you turn it. Kinda defeats the purpose of a rod end, might as well get poly. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It "could" bind if it moves to much laterally (left and right), but the rear-end is only supposed to move vertically (up and down). If it moves in the lateral, the tires will crash into the fender and bad things will happen there so its a direction of travel that is not needed. Even with the rod ends "locked over", it still gets a good bit of lateral movement (far more than you want.....once again....rear-end moves sideways.....BAD!!!).
later <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Chris
