Eibach install
Old Aug 2, 2006 | 05:31 PM
Vols Fan's Avatar
Default Eibach install
Hey guys started my install this evening an hope to finish up tomorrow. I have a couple of questions. Should I reuse the rubber pad on the rear springs or get heater hose? Can anyone tell me any tips or tricks to getting the front shocks off? This is a Pro kit that is being used with 18" ZO6 wheels an revalved bilstien shocks.
Old Aug 2, 2006 | 05:48 PM
OldeSkool's Avatar
keep the pad... unless you want the back end low as it goes.
Old Aug 3, 2006 | 08:19 AM
leadfoot4's Avatar
The retaining nuts on the top of the front shocks tend to get rusty from trapped water. I would suggest getting a pair of new ones, in case you have to cut the current ones off.
Old Aug 3, 2006 | 08:39 AM
Vols Fan's Avatar
Where do you get them at?
Old Aug 7, 2006 | 04:57 AM
leadfoot4's Avatar
You could try the dealer, or, if you have a local hardware store that has an extensive inventory of nuts and bolts, they might have them. It's been a LONG time since I installed my Eibachs, but if my middle aged mind remembers correctly, they're metric nuts.
Old Aug 7, 2006 | 07:38 PM
Vols Fan's Avatar
Found out they are M10x1.5 standard at any hardware store.
