vibration in steering wheel when stoping....
Old Mar 7, 2003 | 01:40 PM
Dean-o's Avatar
Default vibration in steering wheel when stoping....
Does anyone know what in my brake system could be causing vibration in my steering wheel when I stop? Coming to a stop my wheel vibrates and when I let up on the brakes it quits. So it has to be something with the brakes. I only have 16,000 miles on my car although it is a 1999, so I am not under warranty anymore.
Thanks,
Dean
Old Mar 7, 2003 | 01:47 PM
TTtop's Avatar
Default Re: vibration in steering wheel when stoping....
Maybe your brake rotors are warped a little. Have you hit the brakes hard repeatly, say at the drag-strip or elsewhere?
That's where I would start looking. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Randy
Old Mar 7, 2003 | 02:09 PM
Cartonic's Avatar
I agree with TTtop, check your rotors. Stock rotors suck I'm having to do mine also and I just crested 16,500mi. with the same prob.
Old Mar 7, 2003 | 02:42 PM
Dean-o's Avatar
Do your rotors? Replace or turn them?
And yes I did some hard braking the other weekend thru 105 with the Vette guys. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Damn car should be able to handle that, I bought an SS for the handling and it is supposed to be set up for autocrossing or roadracing. What good is all that suspension if your brakes can't handle it?
Old Mar 7, 2003 | 02:44 PM
deviate42's Avatar
its your rotors. I warped mine after prob 5k or 6k. Get some slotted ones, and youll be fine.
Old Mar 7, 2003 | 11:10 PM
SS Express's Avatar
My 2001 SS does the exact same thing and I have 14k miles. I am sure it is the rotors. I will be changing them as soon as possible.
Old Mar 10, 2003 | 10:40 AM
Camaro00_SS's Avatar
It's your rotors. Cast iron slugs, don't handle heat cycling near as well as they should for this type of car. You can have 'em turned and that will take care of the shimmy for awhile, but if your going to do repeated hard braking (x-cross, light to light drags, etc.), then go with a set of aftermarket discs up front. Slotted rotors are nice to look at, but aren't really necessary. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Mar 10, 2003 | 06:51 PM
trackbird's Avatar
www.tirerack.com
Brembo OEM (stock replacement rotors), look stock, don't warp and cost $61 each. Fix it the first time for cheap!!! Just my .02....
Old Mar 11, 2003 | 01:57 PM
Dean-o's Avatar
Do you have experience with the Brembos?
