quick question about a brake job
I'm going to be changing out the brake pads and just want to know if you always turn the rotors when you change the pads?? By the way I have no indication of warping so I don't want to screw with them if I don't have to.
thanks
steve <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
thanks
Agreed, the correct thing to do is to turn them. I used to work at an autoparts store taht also turned rotors and I'd say that 10-15% of our customers actually did that. If the surface is flat (no visible grooves, etc), you can get away with changing pads and letting them "break in" to the rotors. I don't really like to recommend this approach, but I have used it on occasion and never had any problems. It takes common sense...and if in doubt....turn them. Good luck!
Thanks guys, I appreciate the input!!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Are you replacing the pads with stock or with something better than stock. If so I would get a better set of rotors just to stand up to the demands of the higher friction pads. Your stock rotors may not be warped now, but after a few good stops with good pads on you might have your wheels off next weekend changing rotors this time
