So lowwwww
Old Aug 8, 2006 | 09:50 PM
SiL3NtXWS6's Avatar
Default So lowwwww
I just put QA1 Rs in the front with 300lb springs and the car sits so ungodly low. We have messed around with them a ton, moving the spring perch up a lot and still nothing.
Does this look right? Was your perch farther up?
Old Aug 9, 2006 | 12:32 AM
DONAIMIAN's Avatar
BMR makes spacers to help out with that. I saw em on speed inc's website.
Old Aug 9, 2006 | 11:21 AM
SiL3NtXWS6's Avatar
I better not have to use spacers... I just want to know if other people's spring perches sat higher than mine for stock ride height
Old Aug 9, 2006 | 11:28 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The bottom adjuster will need to be VERY near the top of it's adjustment to get the car to stock or near stock height. They design the springs this way to get the maximum amount of stored energy.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Aug 9, 2006 | 12:42 PM
2001 Pewter WS6's Avatar
Restricted User
I think mine is up 49 threads from the bottom for a 1" drop. It will be about 1" - 2" from the top of the threads..
Old Aug 9, 2006 | 05:42 PM
BlackHawk T/A's Avatar
Wow I like that...adjustable spring perch? So it just screws up and down on the threads?
Why don't people ever talk about these when they want a drop without increasing spring rate...must be something I don't know.
Old Aug 9, 2006 | 09:30 PM
SiL3NtXWS6's Avatar
thanks for the help guys
Old Aug 10, 2006 | 07:50 AM
YellowToy/A's Avatar
Springs keep the car off the road. If u lower the with the same rate springs and u hit a bump the car will be closer to the ground. Works for a drag car. Not as well for a DD.
Old Aug 10, 2006 | 02:24 PM
BREAKPARTS's Avatar
QA1 coilovers are expensive,but well worth the adjustability in both shock stiffness and ride hight for muscle cars...so i can imagine what they can do for our f-bodys.
Old Aug 10, 2006 | 06:26 PM
2002ssls1's Avatar
I have the qa1 shocks with the eibach pro kit, and the spring perch is very close to the top, but it is not a nice ride at all, I am at a loss as what I should do. Any suggestions?
