noise re- abs
Old Apr 19, 2003 | 08:33 PM
beaner39's Avatar
Default noise re- abs
hello, i have a 98 z28. whenever i start the car there is a really noticeable noise coming from under the hood. my local mechanic said it is the abs starting up and going through a cycle. it lasts for about 10 seconds. it does this at every startup and is fairly loud. does anyone else have the same loud noise from their abs upon startup? thanks , beaner 39
Old Apr 20, 2003 | 09:07 PM
trackbird's Avatar
Default Re: noise re- abs
Mine is quiet (2002 Z28)....
Old Apr 20, 2003 | 09:09 PM
trackbird's Avatar
Mine is quiet (2002 Z28)....I'd get (or borrow) an actual factory shop manual (from Helm Publishing). The manual will run about $100, it is worth every penny (if you do much work on your car).
