Braking Problems..Need Help
Old Aug 9, 2006 | 09:04 PM
JacobK's Avatar
Default Braking Problems..Need Help
Im having a problem with my brakes lately..When i brake hard, like after i go through a few gears and get on the brakes, my brake pedal get EXTREMELY hard and i have to let off it and get back on the brakes. I dont know what the hell is going on with it. I just replaced the rotors and pads not too long ago..But im thinking of replacing them again..What does it sound like is going on? Car has 125K miles on it and mods in my sig.
Thanks
JacobK
Old Aug 9, 2006 | 10:11 PM
ksuburban's Avatar
might be the booster going bad
Old Aug 9, 2006 | 10:39 PM
JacobK's Avatar
is there anyway to test it?
Old Aug 10, 2006 | 12:38 AM
ksuburban's Avatar
ya, with the car off pump the pedle a few times. the pedle should get hard. with your foot on the brake start the car. your brake pedle should go down. But that will only hapen if your booster is compleatly shot, and it doesnt sound like it is. Also listen for a hiss noise when stepping on the brakes. also make sure that the source vacumn hose to the booster is not kinked
Old Aug 10, 2006 | 04:29 PM
JacobK's Avatar
do you think it could be something to do with the ABS?
Old Aug 10, 2006 | 04:35 PM
ksuburban's Avatar
anythings possible but probley not. thats not really a symptom of abs false activation. and i doubt that the valves in the hydrolic control unit are stuck cause if they were that would set a code and the abs light would come on. the abs system self test its self every time you start up the car and drive it. but without driving it theres no way to say for certain.
Old Aug 10, 2006 | 05:40 PM
JacobK's Avatar
sometimes when i stop really hard, my low traction light comes on..
Old Aug 10, 2006 | 09:49 PM
DONAIMIAN's Avatar
Thats normal, at the same time you should feel the abs doing its job.
Old Aug 11, 2006 | 11:12 AM
JacobK's Avatar
right, but should my pedal get extremely hard, and stop like a 1/2 inch from the top
Old Aug 13, 2006 | 06:29 PM
JacobK's Avatar
I tried this and the pump didnt go to the floor, but i did hear a hissing noise..
Old Aug 13, 2006 | 11:47 PM
JacobK's Avatar
Ttt...
Old Aug 14, 2006 | 01:17 AM
1999Z28's Avatar
the 90 degree plastic connector that connects the hose to the booster is a check valve. make sure air only passes one way through it.
Old Aug 14, 2006 | 02:32 AM
JacobK's Avatar
how do i make sure air only passes one way through it? Sorry im not really mecanivcally inclined..
Old Aug 14, 2006 | 03:40 AM
nebraskaTA's Avatar
Maybe take it off and blow? I don't know for sure though.
Old Aug 14, 2006 | 03:49 AM
nebraskaTA's Avatar
From haynes manual. power brake booster inspection.
Operating check:
Depress the pedal and start the engine if the pedal does down slightly, operation is normal.
Depress the brake pedal several times with the engine running and make sure that there is no change in the pedal reserve distance.
Airtightness check:
Start the engine and turn it off after one or two munutes. Depress the barke pedal esveral time slowly. If the pedal does down farther the first time but gradually rises after the second or third depression, the booster is airtight.
Depress the brake pedal while the engine is running, then stop the engine with the pedal depressed. If there is no change in the preal reserve travel after holding the pedal for 30 seconds, the booster is airtight.
