Torque Arm Doesnt Fit..
For different reasons, plenty of people have to do this sort of things. I had to grind the very tip of the corner off the rear of my UMI TA to fit on my 8.8".
Ben T.
Pictures would be great as well, we have never had a issue before. Unless this is a 9", I know 9" rear end will require some heavy grinding on our non-adjustable torque arm.
Give me some information and possible pictures and I am sure we can figure it out.
Thanks,
Ryan
We have installed and sold many of the non-adjustable arms with no troubles so I am sure it is something we can figure out. One thing you can note, if the powder coat is heavy it may not let the arm slide on fully. It may require some sanding of the powder coat to allow it to slide on completely. Between GM tolerances and trying to hold a powder coat thickness this is common.
Let me know how it works out.
Ryan
Please it at all possible I need pictures of what the issue is.
Thanks,
Ryan
It sure seems weird that everbody's TA will bolt up but yours... especially since this piece is cut out on the same CNC program theirs was.
I say have your mechanic talk to UMI.
Ben T.
Ben T.
