'98 Stock Front Sway Bar...What Size is it?
I believe these are 32mm, but I wanted to double check before ordering new bushings and endlinks. Reading through searches I wasn't positive that the '98 WS.6 had a 32mm or 30mm. I busted an endlink last night, and figured I'd replace everything when I bolt it back up.
Also, anyone have the correct part number for energy suspension bushings. I see one for 32mm(9.5116), but a different one (3.5162) listed specifically for our vehicle.
Careful, some early SS/WS6 cars had 35mm front bars and 21 or 22 rears. This is also true of some later SLP equipped cars. Do a search and you'll find it. Bottom line, you gotta measure to be sure. Standard Z28 and TAs had 30/19 stock, that I am aure of. JUST did front 32mm bar and poly all around so it's fresh in my head. I ordered my bushings and end links from Autozone.\
Good luck!
Good luck!
