Front Wheel Hub removal
Does anyone have any input on removing the front wheel hub assembly from an LS1 car? I have the 4 bolts out and the hub is stuck in place. I can't hammer it too hard because I am afraid of damaging the bearings.
Since everyone is so curious as to why anyone is doing something, I'm replacing the wheel studs on the front of my '99 T/A. I've already done the rears. I'm replacing them because some of them are stripping and breaking due to too many wheel/tire changes (I change wheels/tires for autocross racing). I am installing the ARP hardened studs that I shortened to stock length (so I can use my chrome closed end wheel nuts).
OK, guys, thanks. I tried to budge these things before I posted my problem. I tried WD40 and I tried knocking hard on the sides with a sledge. I tried prying and I even hit the back side of the flange, afraid that I could damage the bearing. I tried big channel locks, too. ROCNDAV, I hadn't thought of hitting the bolts. That was a good idea. And I thought I was halfway smart and experienced. Learn something new every day. After continuing to douse the seams in WD40, I had to bang the holy crap out of the bolt heads to finally get the hubs to start showing a little crack. I continued to bang evenly on all 4 bolts (turning the wheel lock to lock so I could get to them), and they finally came off. Now I just have to buy new bolts or use a lot bigger socket. At least I think the bearings are still good. Now on to other stuff after doing something that I thought would be much simpler.
