My Ebrake Sucks!!!!!!!
Thanks
Andy
Andy
Secondly, it wasnt meant to be used while driving. An F-body isnt a Rally car and doesnt have brakes that can be utilized, like that of a Rally car.
Sneakyws6 has written an adjustment procedure that should work just fine. And to expound on this a little more:
If the gap between the adjuster nut and screw exceeds 0.25" (5mm) during the adjustment procedure the brake shoe needs to be replaced. Adjust the P-brake shoe to drum clearence to 0.015" (0.38mm).
When you install the wheels, only finger tighten the lugs. Cycle the brake lever three or four times and then check the rotor for drag. If there is drag present recheck and adjust the shoe to drum clearence.
**just some food for the mind**
btw inside the tranny there is a parking pawl/gear in the auto's that hold the car in place when your in park, somtimes if your violent enough it'll snap the tooth and wont hold the car anymore, the parking brakes were put there to be used to apply the brakes when you park to save that pawl/gear in the back of the tranny from breakin on you. imagine putting the car in park and it not hold and just moving around like it's in nutral!!
this isnt the 4l60E tranny (it has one though) but it gives you an idea of what i'm talking about looks like
FYI the directions on page 1 are dead on but the direction that you need to spin the adjuster on each side is opposite from what's posted.
Andy
Part of removing the center console is using something to "pry" and hold back the piece that contacts the teeth so that the handle can be angled in a better direction without engaging the brake. I've heard of the backing up a couple feet to adjust the parking brake but I've never tried it.
