My Ebrake Sucks!!!!!!!
Old Aug 30, 2006 | 09:48 PM
GREATWALLTA's Avatar
Default My Ebrake Sucks!!!!!!!
I try to test out the Ebrake on my car today while driving. I was going like 10MPH or less, and put the tranny in nutrual then I pulled the Ebrake and it barely slowed down the car at all. Is it just me or does the F-body's Ebrake sucks to use while driving.
Old Aug 30, 2006 | 10:06 PM
Divergent Lightning's Avatar
Mine stops my car quite violently when activated. Maybe yours is worn out? Have you accidentally driven with it engaged once?
1999Z28's Avatar
they have shoes on the inside of the rear rotor. are you sure yours arn't completely wore out or just way out of adjustment?
Old Aug 30, 2006 | 10:56 PM
Nick04's Avatar
LS1Tech Sponsor
yeah, alot of times its just how they are set. Mines pretty usless as an E brake, its more of a "parking break." That can be adjusted though. Or of course, god gave you a shitty brake.
Old Aug 31, 2006 | 10:49 AM
Well my car is a 2002 Trans Am, A4, so I don't think my Ebrakes are worned out. But can anybody tell how to adjust it to make it tighter? or is it even possible to adjust them?
Old Aug 31, 2006 | 03:19 PM
coolformula's Avatar
Should be in your haynes manual. Different ebrakes adjust differently
Old Aug 31, 2006 | 03:34 PM
Sneakyws6's Avatar
On the tree
No all LS1 ebrake all adjust the same. The shoes will almost never be worn out unless you drove with the ebrake on.
Here is what you do.
Get the car jacked up and pull the rear wheels.
now you will need to remove the calipers with the brackets. Dont pull just the calipers, make sure you pull the bracket with them. There are 2 12mm bolts that you remove and the bracket removes with the caliper in it.
Once they are off tie them up so they dont hang by the hose. Now make sure the ebrake is off or all of the way down. Now pull one rotor off and at the bottom of the rotor on the backing plate is the adjuster plate.
It has a small wheel with teeth on it. Rotate the drivers side wheel from top to bottom with a flat blade screw driver. The adjuster will slowly come out. The passanger side goes from bottom to top to rotate it out if memory serves me right. I sometimes have to watch it to be sure.
Now that you know how they work here is how I do mine.
I pull my handle up about 6 to 10 clicks then pull one rotor off and adjust it until take some tension to get it on the hub. Once I get to that point I release the ebrake and put that rotor on and pull the ebrake back up to the 6-10 click set point and make surde the rotor is held firmly.
If it hold then I go to the other side and repeat the procedure on that side until I get both to where they are held firmly at 6-10 clicks of the ebrake handle.
It will take several times back and forth until you get it to where you want it. I ahve mine set to where it hold at the above point and I can lock the rear up if I wanted to, but I at least know it holds when I need it to hold.
the inherent problem is the adjusters, they tend to rotate back in a loose thier gap over time. About twice a year I adjust mine.
Any questions let me know. I have done mine several times because of some dealership mistakes and I drive a M6 car so I prefer to know my ebrake will hold the car when it is suppossed to.
Old Aug 31, 2006 | 05:34 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
mine stops like 'right now' when i pull it.
Old Aug 31, 2006 | 06:09 PM
s1ck s0n's Avatar
i can use mine to slide around
Old Aug 31, 2006 | 07:57 PM
presto_z's Avatar
i use my gas pedal for that
Old Sep 1, 2006 | 12:38 AM
s1ck s0n's Avatar
well yeah me too. i use the ebrake for sliding into parking spots.
Old Sep 1, 2006 | 04:03 PM
Wow I would actually want to see a vid of this done in your car. Any way you can post one. I think it will be entertainning.
Old Sep 1, 2006 | 04:08 PM
s1ck s0n's Avatar
lol, ill see what i can do. im not talking about parallel parking, i dont have the ***** to try it. but i do it at wal-mart all the time.
Old Sep 1, 2006 | 06:20 PM
Revelation Z28's Avatar
my e brake handle only needs to be pulled to 4 clicks to be tight.
Old Sep 2, 2006 | 02:39 PM
Well I guess its just my car that has this freaken problem then. I guess I would have to do the adjustments on it and see if it will help. Goodthing I have a A4 and don't depend on the Ebrake as much.
Old Sep 2, 2006 | 03:10 PM
kenkaru's Avatar
my ebrake sucks too. You're not alone
Old Sep 2, 2006 | 03:33 PM
boondiggys's Avatar
yes it sucks, join the club
Old Sep 3, 2006 | 02:34 AM
BLK02TA's Avatar
My ebrake = teh sucketh
Need to adjust
Old Sep 3, 2006 | 02:55 AM
dopy's Avatar
I thought driving backwards with the ebrake on for a few feet would adjust it?
Old Sep 3, 2006 | 04:23 PM
Hawk108's Avatar
I wanna see some e-brake slide vids!!!! i used to do that stuff in my gti and do 180s!!
