Will Bilstein HD shocks hold up?
You are best to get a set of Bilsteins re-valved to match the Spring rates. The HD's are not designed to lowered cars, those springs may wear the shocks out much quicker. I suggest calling Sam at www.stranoparts.com, he sells Bilsteins re-valved for those springs, it won't cost much more and is worth it.
Hope that helps!
Ryan
Hope that helps!
Ryan
LS1TECH Sponsor
You decide. Read the top of the page and then consider the advice you've been given:
http://www.bilstein.com/302passengercars.pdf
__________________
Thanks for the help everyone. So the Bilsteins that arent revalved will not be able the spring rates of the prokit. Eh , i was just curious to know if the regular HD's would handle them . Ill leave the car as is for now , seeing that i dont have $750+ to throw down on the springs and revalves. Again thanks for the help.
