Before and after pics with Strano Springs!
#42
LS1TECH Sponsor
Sure thing....
__________________
#43
Here are some "action" shots of my car with Strano Springs / Koni SA shocks:
![](https://i48.photobucket.com/albums/f208/OUTLAW1970/DSC_3294-900.jpg)
![](https://i48.photobucket.com/albums/f208/OUTLAW1970/DSC_3368-900.jpg)
![](http://www.musclerides.com/Images/pf_2006/autox/IMG_9067.jpg)
![](http://www.musclerides.com/Images/pf_2006/autox/IMG_9068.jpg)
The cars handling is night and day different from the stock setup I was running in autocrosses previously.
#45
Originally Posted by SpdFrk1990
Did you have the fronts on the lower perc setting? Also did you do the rear hose mod?
#50
LS1TECH Sponsor
This was posted today in another thread: https://ls1tech.com/forums/suspension-brakes/644012-sneek-peak-new-setup.html
__________________
#51
Sam we spoke for a good hour a week ago about my 02 ws6. (Kyle) I had an eclipse before this car.
The stance isn't really what i'm looking for, but i guess that might be the best option for the fbody since the exhaust hangs so low with any aftermarket solution... even my prokit is too low to add headers.
is there something with a little more drop than the strano springs that offers a higher spring rate than the eibachs?
#52
#53
LS1TECH Sponsor
He wants it lower, not higher. Please read the details....... ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
There are lots of springs with more drop and higher rate. But that's not the entire deal, you also have geometry issues, mechanical grip concerns and so on that go into a set of springs--or should but often don't.
I guess the old addage you can please some of the people all the time, or all of the people some of the time is true! The springs are rates I know work and have used with great success. The ride height is set as low as I can go without causing major issues with geometry, travel, and even header clearance (but that varies depending on your headers and I won't compromise the suspension because some headers fit like junk). So really, IMHO any lower starts you down a if/then compromise road.
__________________
#55
Sam, If you are still here,
Will your springs make my 2000 Formula w/ Koni SA's and 35/21mm bars ride and handle similar to the third gen. '88 Formula 350 WS6 I had with a stock setup and KYB's or will it not be as harsh??
I think the spring rates on that third gen. were like 700+ / 200.
#56
sam, i want to call you today around 1pm pacific to try to finialize my order.
i think i do really want a nice stance on my transam, and im very happy with how it sits now with LS1 prokit, but i often ponder if a higher spring rate (of your springs) is going to be something i like for its handling, or if i will not like it for the harshness.
maybe just the SAs and the sway bars will be a big enough improvement....
#57
LS1TECH Sponsor
I was saying from all the pictures ive seen hotchkis seems to be a little lower even tho the advertised only says 1".
__________________
#58
LS1TECH Sponsor
__________________
#59
LS1TECH Sponsor
It would ride better than the 3rd gen did, and handle similarly. I've owned and raced (and won) in both 3rd gen and 4th gen cars, so I'm familiar with both. And the spring rates on a 3rd gen don't mean much because the fronts are located in a COMPLETELY different position which means the spring are different rates to account for motion ratios. And the rear springs weren't 200 pounds. Usually about 150-ish, give or take a few (there are 6 rear springs) which happens to be what my rear springs are.
__________________
#60
Yeah, that was me emailing. I'm going to get one of your SA packages eventually, so I'm trying to decide on which spring would be best for me. My choices would be Prokit, Strano, or stay stock.
I was pretty sure the springs were further inboard on the third gen. thus requiring the higher rates. That car was rode like a brick, handled like a NASCAR, but it had no traction off the line.
greg
greg
