c5 brake upgrade with fbody rotors?
PM me and I will give you the link because they are not a sponsor and I don't want to stir anything up, or just go google "kore3 industries"
The brackets were pretty cheap, call your local dealers
Originally Posted by MiaSSmaro98
were can i see the bracket and whats the price on it and the c5 abutment
New they are pretty pricey. The caliper bracket were around $200 when I priced them.
I ended up finding a used set of Z06 red calipers with brackets for $150
I used C5 rotors, F-body calipers and abutment brackets. I did not have to use the C5 abutment brackets. It's not 100% necessary and I have done this 3 times now on various cars.
ok so i will need the kore3 bracket which one though?and a c5 rotor thats all?all my hardware will bolt up?
Oh and its recommended you buy the C5 front brake line kit too. It's a smart idea to go with those as they are a bit longer than the F-body lines and with moving the caliper out, its nice to have the extra slack.
what do i ahve to cut?and do i have to buy the c5 abutment?because one stated he used his fbody
You have to cut the lower bolt hole for the factory caliper. When you take the factory caliper and rotor off, you will find out real fast what has to be cut. The company who makes this kit also gives you detailed instructions on what to do. Pick up the phone and call them!
Originally Posted by Trent
Jeez dude did you not read what I posted? You do not HAVE to use the C5 abutments. Some have better luck with them or have to use them. I have not had to.
Be safe!
Originally Posted by trackbird
Be careful, the C5 PAB has 14mm bolts to attach it, the F-body has 12mm bolts.......Be safe!
I speak from experience, you will need the C5 abutment brackets if you use the Kore3 big-brake brackets. I am not sure about the other brands. The C5 and F-body rotor backspacing is different so your F-body abutment brackets will hit the C5 rotor. You may be able to get by with a fraction of a millimeter of rotor clearance, but do not mess around with the safety of your brakes. Your lives and others depend on them. Do your brakes right the first time so that you trust them.
Also, the F-body abutment brackets use smaller hardware like trackbird said. Without the C5 abutment brackets, the supplied heavier hardware won't even bolt up to the factory F-body abutment bracket. The F-body calipers will fit the C5 abutment brackets and sliding pins just fine. I will see if I can find the instructions and scan them. Give me a few days to go home and get them, as I am away at school. If I can clarify at all please let me know what was not clear and I will help as best I can.
#32
well ive tried searching for the c5 brackets cant find nothing used so how much are they new
I think its $224
Trust me it's better to wait untill you find a pair of used c5 calipers that come with the brackets.
My c5 calipers with brackets were $150
#34
Were At?
#36
well gm parts direct is alot cheaper then the dealer.so if someone can post the part numbers we can order it through them
#38
Originally Posted by 92SilverSHO
does that include pads/rotors trackbird? i have team chevrolets email.
