pinion angle for a 99 bolt-on F-body?
I know many guys have been through this so after your experiences with setting up your TA's, what would be a good starting point for pinion angle on a 99 bolt-on F-body? I have the Spohn TA, LCA's, PHB, air bags and I want to run it hard at the track on weekends so a track setup that doesn't make driving on the street evil is what I am looking for. I will be launching on 11" Nitto DR's.
Thanks in advance.
Thanks in advance.
Originally Posted by Viper
-2 degrees. I did that with bolt on's and kept it now that I'm making more power. Works for me.
Ok, so standing behind the vehicle and refrencing the front of the rear end....
1). do I want the rear end pointing down towards the front tires
or
2). do I want the rear end pointing up towards the sky?
or
There was a good article that I cant seem to find on here about pinion angle.
Is the pinion supposed to be facing down -2 degrees towards the front of the car or up towards the sky? Is it supposed to make a 'V' or a '^' in some sense?
From what I have heard, is that the pinion should be facing down towards the front of the vehicle -2 degrees in relation to the d/s.
-2 degrees here.
It's pretty simple actually. At perfect level looking at the car from the passenger side imagine a line going through the yoke at perfect level. That is 0 degrees. Rotate that line to -2 degrees, so turn the yoke toward the ground 2 degrees. The reason you go negative is because the torque is going to rotate the yoke upward and when at WOT you want the yoke at 0 degrees for the best transfer of power.
If anyone can come up with an easier explaination please do.
Thanks for confirming that Firebird!
Thats what I have been doing, setting the yoke on the rear to point down towards the front of the car at a specified angle, whether it be -2 or -3.
Sunday will be the first track day for me, any bets as to how fast I can get this stock powered/HP Tuned by mE full weight 99SS down the track with the 4.10's and some rear suspension mods. I'm shooting for low 13's but nothing would surprise me. I will have to bog and roll with the stock clutch and stock M/C but that should only give up a 10th or two.
I'd say with your mods and cool air you should be at 12.9 or so. I wouldn't be surprised if you had a better time. I can run 13.1, 13.2 all day with the tires spinning and hoping. You have a steeper gear and more traction. Plus the 6spd will help.
The only thing I'm a little apprehensive about is the hydraulic clutch before I have a chance to set it up better, wish it was a cable instead.
movies, .... of course!
