Which shocks should i get
Old Oct 9, 2006 | 11:42 PM
Ls1_TA's Avatar
Default Which shocks should i get
I bought some intrax springs a while back and if i remember correctly they should lower my car about 2 inches.What kind of shocks should i get or what would you recommend.I was just about to buy some kyb adjustable shocks.Im on a tight budget right now so i dont need the best but something descent.
Old Oct 10, 2006 | 10:19 AM
dragonrage's Avatar
Avoid KYB.
Old Oct 10, 2006 | 10:30 AM
Ls1_TA's Avatar
what brand should i go with?
Old Oct 10, 2006 | 10:54 AM
dragonrage's Avatar
Bilstein revalves or Konis, contact Sam Strano. You say you're on a budget and if that's true then go for cheap shocks on stock springs
Old Oct 10, 2006 | 12:57 PM
Ls1_TA's Avatar
Thanks for the help.How much would Bilstein revalves or Konis cost me?
Old Oct 10, 2006 | 03:42 PM
02SS#406's Avatar
$500-$750
Old Oct 12, 2006 | 09:03 PM
Nix_WS7's Avatar
Dont mess around with KYB sssun. Save up alittle longer for the Koni single adj. yellow struts. Go to www.ws6project.com they have the best deal on them that I've found. $479 I believe, it's steep I know but they are made of a 2 inch drop. Infact I called KYB, Tokico and Bilstein and talked to there Tech department. They all said the most drop there shocks are made for was an 1inch 1/4 and I think they know what they are talking about.
I have Eibach sportlines and I'm planning to go with Koni. I will let you know how it handles once I can afford them.
Old Oct 13, 2006 | 08:01 AM
sgarnett's Avatar
That's for fronts only
Old Oct 13, 2006 | 09:52 AM
coolformula's Avatar
Must get the revavles(hopefully that will work) Konis would be ideal. I don't know the spring rates of them right off.
Look at about 800 bucks for shocks or I would return to stock springs.
