Brake fluid change
To make it even easier, you can use something like Ate Super Blue, and wait until the fluid coming out is completely blue (then you'll know it is fresh).
Whatever you do, don't let the Master go dry. As stated, that would be a "hell of a bleeding issue."
http://www.installuniversity.com/ins...sity/index.htm
I've only been able to buy Ate online...a Google search will come up with some for you. Pretty sure it is a DOT 4 fluid.
Edit - click on that link, go under "Install Documents" on the left hand side of the page, and under Braking, click on "Brake Caliper Rebuild".
It's actually DOT 4 (which means it surpasses DOT 3 specs by a mile), had a 536 dry boiling point, and a very high 392 wet boiling point.
