New front brake setup, what do ya think?
Originally Posted by jeffstar
In fact, what exactly would the problem be that it would create?
A pad makes friction where it touches a rotor. Rotors do not transfer heat very well internally (they do it, but not well). So, if you could heat a 4" wide section of rotor with a wide pad, you'd typically be better off than trying to heat a 3" wide section of rotor with a thinner pad and counting on the rotor to "wick" the heat to the last inch of rotor that you don't have touching the pad (like with the 4" wide pad in this example). So, you might see slightly earlier pad fade due to heat with a pad that's overhanging the rotor (instead of making full contact). However, for street use, it's not likely to be much of an issue.
Originally Posted by trackbird
The main problem would be a reduction of brake effectiveness. Now, before anyone argues with me that pressure is determined by piston size (which it is), there's something else at work to consider.
So say, a .66 mm of the rotor, temporarily, upon revolution comes out behind the pad "could" have an impact on brake effecitvness?
Seems almost impossible. You kept telling me to "Be Careful here"...were you warning me that this could be a big issue and be a safety problem of some sort? I'm really confused now. This doesn't seem like an issue in any way to me, just a novelty point, which in fact I appreciate the explanation. However I got the impression from you that this was some major issue and using my stock calipers with the LG brackets was a huge no-no. Seems untrue at this point and it's perfectly safe and practical to use the factory caliper with the LG bracket.
I got the impression from you that this was some major issue and using my stock calipers was a huge no-no. Seems untrue at this point and it's perfectly safe and practical to use the factory caliper.....
Originally Posted by SLIKWS6
Keep addressing it here please.
