need help determining pinon angle.
You can never tell be looking at it.
First, I assume ES means a Energy polyurethane mount. It will throw off the angle, if you use the pre-load plate. If so, remove the plate and grind down the 2 bumps on the bottom of the poly mount. This will correct the angle and reduce most of the vibration. The stiffer mount will transmit more vibration regardless of angle. If you are not using the pre-load plate you should be OK.
With the car level and supension loaded, you can check the pinion angle with a protractor. The car does not have to be perfectly level. Find a flat piece of road somewhere. It is very difficult to get under the car with a protractor, when it is not on a ramp. Good luck and buy a protractor.
I believe the stock pinion angle is zero +/- 1/2 degree. So the pinion should point down about 1/2 degree more then the drive shaft angle.
I hope this helps.
JA
FYI - The crank pulley face is normal (90 degrees) to the crank centerline which is parallel to the trans mainshaft centerline. Setting the pinion yoke at the same angle makes it normal to the trans mainshaft centerline. From there you adjust the pinion angle as desired.
If it is speed specific, as apposed to engine RPM, then it could be the angle. Check it carfully in all gears. When I installed the ES mount I got alot more vibration starting at about 2500 RPM. It vibrates at this RPM in all gears.
JA
