Need help with BMR torque arm relocation bracket.
Best of luck.
Re 98, A4 - stock ride hight
I have the same unit. I originally mounted the torque arm as high as I could, while not hitting the under side of the tunnel. It is very tight in there. I assume the top hole will not work on many cars without hitting. I figured higher was better for traction (increase the instant centre).
I noticed alot of thumping through the floor at the consol and my rear supension became quite rough riding. Later, I moved it down to approximately level. I believe this was 3 holes down from top. It realy smoothed out the ride and no negative affect on traction. Big improvement form a small adjustment.
I assume the front part that slides in the poly bushing needs to be about level in the bushing to get full freedom. If not, it restrics some movement. Thats just my theory.
I would say set the torque arm about level at the top.
JA
