Steering shaft linkage question and problem..
About half way up, on the flat, you will see a small circle, about teh size of a pencil lead. That's the shear pin.
But because the 2 sections that fit together are flat/oval shaped, the shaft can't twist inside of itself.
I would suspect either the pressure bypass valve is sticking or the rack is shot.
The bypass valve is located on the pump where the HP line attaches. Unscrew the line, and there is a hex surface machined into the pump and it comes out. Behind it is some valving and a spring. Be careful ... the spring is compressed.
With the PS cap off and when i turn the wheel, can the fluid be seen moving?
