Is this the Caliper Pin? (Picture inside)
Old Oct 23, 2006 | 10:55 AM
lrk322's Avatar
Default Is this the Caliper Pin? (Picture inside)
Hey guys Im confused about which is the caliper pin that I need to grease. Is it this rubber boot in the attached picture with the wrenches on both sides of it that I remove? Then the metal piece that the caliper bolts into is what I grease on the outside? I imagine I need to make sure no grease gets on the bolt? Also youre supposed to use locktite on all the bolts right?
Thanks,
Lane
(click picture for bigger size)
Old Oct 23, 2006 | 11:59 AM
YouCantCmyZ28's Avatar
yup, that is the slider bolt. once you take that bolt out what i usually do is clean the bolt and the slider pin and then if you want you can put a little in the slider, it also ok if you put a little on the bolt too. NO you dont have to put lock tight on them. GM does it on ALL of their the braket bolts but its not necessary in my opinion. let me know if you need any more help.
