brakes stuck
what could i have forgoten, or done wrong for this to happen...ive done a rotor and pads swap plenty of times....
any help appreciated.
with the cap undone. you shouldnt need a huge amount of force to make the piston go back
Remove, inspect, clean, regrease (with high-temp disk brake grease), and re-install as neccessary. Also check their rubber boots for damage and replace any that are damaged.
Like this one.
https://ls1tech.com/forums/suspension-brakes/599180-help-brake-replacement-problems.html
Like this one.
https://ls1tech.com/forums/showthread.php?t=599180
I got lazy.
I saw both threads and copy-and-pasted my response into both.
