Help brake replacement problems
Old Oct 27, 2006 | 05:43 PM
WhiteStripes's Avatar
Default Help brake replacement problems
I just got a POwerslot rotor/HPS pad kit for the front from New Era and it seems like the pads are too big. They fit in the mounts ok, but when I go to put the caliper back on, the mounting ears hit the little threaded sleeves that the caliper is supposed to screw into. I have the pistons compressed al the way too. Help please.
Paul
Old Oct 28, 2006 | 11:44 PM
massls1guy's Avatar
things to check:
- is your rotor on flush
- did you use a wire brush to clean up the hub/studs when you took the rotor off
- did you use a few lug nuts (backwards) to secure the rotor tight to the hub while you mount the new pads/caliper
Old Oct 29, 2006 | 08:40 PM
VIP1's Avatar
Copy & Paste Moderator
Did you check the slider pins to make sure they slide freely?
Remove, inspect, clean, regrease (with high-temp disk brake grease), and re-install as neccessary. Also check their rubber boots for damage and replace any that are damaged.
