lca install time
Old Nov 1, 2006 | 03:37 PM
NviouSS's Avatar
Default lca install time
for those that put some lca's in yourself (which i'm guessing is the majority), how long did it take you to get everything on and bolted up? i'm supposed to be getting my umi lca's and adj phb on friday and would like to put them on before a local track day on saturday. also, would i need to adjust the phb at all once everything is on?
Old Nov 1, 2006 | 03:40 PM
mattraypharbor's Avatar
20min-30min
Old Nov 1, 2006 | 03:52 PM
jimmyblue's Avatar
Moderator
If you are happy with the current left-right wheel
location then you can remove the old, adjust the
new to identical length on the driveway and just
bolt it up.
Neither takes very long.
NviouSS's Avatar
that quick!? maybe i could get them on that night or early in the morning.
how did you rear supported?
Old Nov 1, 2006 | 04:00 PM
ls1king000's Avatar
I have the UMI adj panhard and it has a lefthand thread so, you can adjust it without removing it. Getting close to the stock length first would be ideal though.
Also, for the adj. suspension parts aren't we supposed to use a external thread locker?
Is it okay to adjust with the suspension under load?
Old Nov 1, 2006 | 04:11 PM
Platinum WS6's Avatar
nope, when you adjust the panhard rod make sure both rear tires are off the pavement. Just put the rear on jackstands and adjust it accordingly. Like someone said earlier, if you have stock ride height adjust it to the stock length and then make the changes you want from there. It doesnt take long at all to do the LCAs and panhard rod. I'd say an hour with adjusting. Maybe a little longer if its the first time you have worked with the rear suspension stuff. Easy job though, good luck!
Old Nov 1, 2006 | 04:22 PM
nodnarb481's Avatar
depends on tools and such...
in my driveway with shitty supply of tools...2 hours to install panhard rod...
on my neighbors lift with a whole lotta tools.. 1 hour to install lower control arms, relocation brackets, and re install panhard rod (adjusted this time)
Old Nov 1, 2006 | 05:40 PM
Switchblade's Avatar
It took me about 30-40 mins to install the lca's and the adj panhard bar, and thats with a car lift at a DIY shop which made these installs easy to do. Plus I had the suspension unloaded when I did the installs. The suspension then was loaded for the tighten all bolts on the lca's and phb to spec.
Old Nov 1, 2006 | 09:59 PM
NviouSS's Avatar
this will be done in my garage w/ramps and jack stands
Old Nov 2, 2006 | 12:33 AM
gmpower's Avatar
bolt it up.
Im not too familar with the suspension mods , but what is an adjustable panhard rod? what does it adjust?
Old Nov 2, 2006 | 09:59 AM
NviouSS's Avatar
taken from umi's website
Our tubular “on-car” adjustable panhard bar replaces the flimsy stock stamped panhard bar while adding increased strength and rear end adjustment. This is a must for rear end centering after vehicle lowering, as well as clearance for running larger tires. The supplied CNC machined double adjuster features left and right hand threads for quick and easy on-car adjustments by simply loosening (2) jam nuts and does not require removal of panhard bar from the vehicle. The spherical rod end/polyurethane bushing combination eliminates most rear end “bind” while not sacrificing your ride quality; this is an excellent improvement for your street or drag application. As well as easy adjustments, our heavy duty panhard bar also increases rear stability, controls side movement and body flex
Old Nov 4, 2006 | 10:44 AM
NviouSS's Avatar
that took forever. started around 11 last night and got the phb and drivers lca on. went to bed after that cuz i was getting frustrated. finished up this morning with the pass side.
Old Nov 6, 2006 | 04:36 PM
2 SSlow's Avatar
LCA are pretty easy...the first one i did was the passengerside...took me 45 minutes driver side took me 10 minutes.
Old Nov 6, 2006 | 09:49 PM
NviouSS's Avatar
i could've been done in a couple hrs but i had lots of trouble getting the pass relocation bracket on and lined up. driver's side went a lot quicker.
Old Nov 7, 2006 | 07:25 PM
Ralls's Avatar
Geese, it took you that long? I did my LCAs in like 30 min. Did my panhard bar in like 5 min. If I saw this tread sooner, I could of gave you some tips.
Besides that, did they help at all?
