Good Torque Arm that will work with my tru duals pictured?
Hello,
With that set-up you will want to go with a transmission mounted torque arm for sure, either our adjustable or non-adjustable will work just fine with that set-up. I pasted (2) links below to the torque arms I would recommend as well as a picture of one installed with a true dual system. If you have any questions please ask and I am glad to help. Thank you! Ryan
www.umiperformance.com/2205.aspx
www.umiperformance.com/2206.aspx
![](http://www.umiperformance.com/images/2205l.jpg)
Man, I really wanted to get away from having it mounted to the tranny. It has got to be hard on the mounts doing a 4K launch on 4.10's with that thing attached. How much power have you guys put to this style mounting apparatus and what are the pro's and con's. I have a Strange S60 rear that is not pictured, does that make any difference?
Hello,
Well we can help with that and yes I too recommend getting it off the transmission at some point to prevent future problems. You can go with a torque arm relocation kit, it allows you to use any transmission mounted torque arm but have it attached off the transmission. Take a look at the link below, it has information as well as many installation pictures. It does get expensive buying both the relocation kit and torque arm but we are running a 10% off sale right now that will help
www.umiperformance.com/2207.aspx
Thank you!
Ryan
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thank you!
Ryan
