Options to correct camber
I'm working on the alignment right now, and I seem to be out of adjustability on the front lower control arm. I have the OTC 7840 tool, makes it a snap to move the LCA around and keep it there. I've got the front bolt sucked all the way in. No mas.
My caster/camber gauge setup isn't here yet, but I'm just out messing around in the shop right now. I still have visible obvious negative camber (even with my carpenters' bubble gauge laid against the wheel). Probably at least 1 degree if not more. The rear LCA bolt is sucked in all the way too. I think I'm as far as the factory adjustments will go. Which way would you go:
-slot the hole inwards ~1/8" to get a little more adjustment out of it (easily done, I have ample tools)
-Adjustable lower control arms, a la Spohn
-Adjustable upper control arms, a la UMI
Thanks for any ideas.
I slotted the outer section of the K-Member in order to get MORE negative camber. I run close to -2* on the race car.
-1* is not that much ...
I'm just guessing right now, I have a camber gauge on the way. I'm going to try tweaking the other side to see how it pans out. I know my car has never been wrecked (I've owned since new), but the knuckle history is unknown. I've got the lower control arms from my 98 in a box here, they look the same except no grease zert on the ball joint.
I did do some searching, found a few threads detailing this problem, but they seemed to be running more drop than I am. Weird. Anyhoo, thanks.
Besides, when spindles bend, they usually bend for less camber and not more (meaning, it would probably go back to stock specs, I've seen a couple that we bent pretty badly). So, I doubt that's it, unless I misread your first post.
Just my thoughts.
If you don't have plates, you can roll the car back and forth a bit to unload any bind on the tires or bushings.
And yes, I was trying to approach 0 camber. Once I get my gauge (got a Longacre billet unit on the way), I'll be able to get an actual measurement. For now, I'm just eyeballing it, so any 'angle' I'm saying right now is just a guess.
This gauge looks very nice. Gonna head out back and make a couple measurements.Nice case was included too.
but this is the way I learn, and I figure that with as many cars as I have, the technique will pay for itself (and I flat out don't trust anyone but me to work on my cars). My car is a daily driver, I ran -1.3 for several years and I ran -1.2 for several years on my 3rd gen. I now run -1.7 and drive it daily. Tire wear increases a good bit as you push beyond the -1.3 range and that's also based on experience.
I still wouldn't suggest that anyone should work that hard to get back to 0, take the lowest setting that it will allow (matching both sides), but not 0.
Just my thoughts.
A quick search for "4.5 castor" shows these results:
https://ls1tech.com/forums/search.php?searchid=4283716
and (Searching for 4.5 caster):
https://ls1tech.com/forums/search.php?searchid=4283731
I know there are tons more threads on it, but those are a few that come up with a basic search.
It's the idea that we might help others that keep most of us coming back (Mitch, Foxxtron, myself and others). We've mostly done this stuff already, and we ask few questions because we've learned many things the expensive way. We don't know it all, but we are always willing to share our experiences in an effort to help when we can. And, worst case, we get a discussion going that brings new data in that we all learn from. And, if I can save someone else all the money I wasted buying the wrong crap, it's worth it.
