caliper movement
I was installing my passenger's side pads when I noticed that the caliper has slight movement from side to side. My question is, are the calipers supposed to move from side to side? Both sides do this, so I figured it was normal but then again maybe both of them are messed up.
I need a quick response if anyone can give me a for sure answer.
You should make sure all four calipers are moving free on the slider pins. Lube them up good.
