LCA Relo Brackets
You will be fine with either the bolt in or weld in, both work excellent. The bolt-ins will not cause any addtional noise and work just as well. If you can't weld or don't know anybody that can then I recommend to go with the bolt in style.
On the brake weight, out of all the sets we have installed we have never actually had to trim it, they fit good. If you ever would have to, its a round rubber weight that just needs a tiny bit trimmed off and is very simple. But again, you shouldn't have to do that.
Hope that helps!
Ryan
Ryan
