Excessive Front Wheel Movement
Old Nov 14, 2006 | 11:22 AM
TAboo's Avatar
Question Excessive Front Wheel Movement
While rotating the tires on my '01 WS.6 I noticed that the driver's side front wheel had some excessive side-to-side play. If I held the tire at the front and back and rocked it side-to-side, it would move 1/8" of so. If I held it at the top and bottom it had no movement. The right side was on the ground during this process. What's the most likely cause? I'm guessing a tie rod end (inner or outer) but wanted to know if that's something that tends to go bad on these cars. And if so which one?
Thanks in advance for any help.
Old Nov 14, 2006 | 01:12 PM
Bio Messiah's Avatar
not your bearings right?
Old Nov 14, 2006 | 01:18 PM
mitchntx's Avatar
Hub play would show up with hands at 12 and 6 O'Clock.
While someone moves the wheel as you describe, look at the tie rod end ...
