Wandering on the Highway
Old Nov 18, 2006 | 08:27 PM
Hawkeye's Avatar
Default Wandering on the Highway
Hey all
I took my Hawk out for a nice cruise on a main expressway here on Long Island today...Just put on AR TTM's (17x9 and 17x10.5) with 275's up front and 315 BF Dr's in the rear...
My question is: The car would not stay in the lane, wandered right to left all over the place...The road is grooved from big trucks....scared the hell out of me a few times...The car was aligned last year...Should the specs be different with the 315's??
The car has 45,000 on the stock shocks, hotchkis lowering springs, lakewood panhard, lakewood LCA's...
Any input on this??? I was gonna throw a can of gas on it when I got home and light a match....My 06 4 runner handles better
Old Nov 18, 2006 | 09:01 PM
z28_theantirice's Avatar
I noticed with the wider tires the car tends to want to follow groves in the road more then usual. The first time driving the car with the new tires it felt a world of a difference, I was a little nervous but now I'm used to it.
Old Nov 18, 2006 | 09:13 PM
qwikz28's Avatar
i hear the Baer Tracker tie rod kit is supposed to help this. its pricey but value is relative if the bump steer is bothering you that much
Old Nov 19, 2006 | 11:17 AM
blkbird's Avatar
I also noticed this once i stepped up to a wider tire...... Its kinda scary sometimes will all the construction that has been going on here lately....
Old Nov 19, 2006 | 09:59 PM
May Spin's Avatar
Let's start with the basics... If done correctly, suspension changes are done to allow the tires to be more compliant. Your stock Decarbons are trying dampen a significantly higher spring rate for which they were never designed to do. They never adequately controled the stock spring rates for that matter. By choising a damper that is valved correctly your tires will be more compliant and you will avoid trammeling. A good shock will also give you the single biggest improvement in overall handling and ride characteristics.
Scott.
Old Nov 19, 2006 | 11:09 PM
Keenov's Avatar
Wider tires find the grooves in the roads a lot easier.
Old Nov 21, 2006 | 03:06 PM
lo_jack's Avatar
You live in SA buddy, it's a wonder you can get anywhere in an fbody and live, let alone with wider tires. I remember what happens when it rains. Road = minefield
Seriously though, wider tires follow any road annomally more, even if your alignment is true. I am interested in hearing about those tie rods though. Has anyone put them on?
Old Nov 21, 2006 | 10:58 PM
1999 SS's Avatar
my 00 TA has the same problem with wandering on the road. it has 245/55/16 and lowered in the front 1 1/4 inches and even after i replaced my front shocks with new oem units it still wandered around.
my 99 camaro is dropped 1.5 in the front with 18' wheels and 275/40/18 tires and bilsteins and i dont have a problem with it wandering but when i had the factory 17's and de carbon shocks it did a little but not as bad as my TA does now.
i think it has alot more to do with choice of shocks than tire width.
